time2roll wrote:
I assume a 9200 would run off a 2000 generator in most conditions.
campigloo wrote:
I don’t know. 9200 btu would be ~ 2650W
If successfully starting a roof mount A/C with a genset is the issue then the better solution would be a 13,500 BTU A/C equipped with a
Micro-Air Easy Start Soft Starter Kit powered with the new
Honda EU2200i which is significantly more powerful than it's 2K predecessor or indeed
any 2K inverter genset currently available. If the OP felt a 9200 BTU A/C would be sufficient the EU2200i would just laugh at the task. :p
