ScottG wrote:
Same setting I use and I can easily feel it. Are all the setting at their default values? If the POD is adjusted down it will directly effect power output.
Also, if you don't have a boost elbow, it would be helpful.
BTW, regardless of what MADs says, you need a pyro. You absolutley CAN get the EGT's too high if your working the truck hard, like pulling a trailer up a steep mountain pass.
I speak from experience.
I ABSOLUTELY AGREE WITH SCOT.
If I did not monitor my egt`s while towing my 14k 5`er, I would have lost my 5.9 MANY years ago.
If you are concerned about high EGT`s try water/ meth injection.
That said you still need boost and egt gauges with the SMARTY on SW2 or 3 when towing.
Scot is spot-on!
