scool191 wrote:
I am so confused by all of this.
I am looking to buy a new travel trailer. I drive a 2011 Ford F150 Supercrew V6 3.73. Per Ford the max tow weight is 5700 pounds.
The trailers I'm looking at have a unloaded weight of 4500 pounds. They very in Grvw from 5800-6800.
So can I get these trailers based on UVW? Or should I look at GRVW.
Guessing trailer weights for F150's, is a scary proposition. Ford built so many different versions. Some with payloads down at 750 lbs, and some over 3000 lbs. Some with tow capacities over 10,000 lbs and some down around 5000 lbs.
That 5700 lb tow capacity number, is only one of the several ratings on your truck. It also indicates your payload may be somewhat low. You need to find out what the rest of your ratings are, and ensure your loading and towing weights stay under all of them. Read the fine print in Ford's towing information. You'll see statements similar to "when properly equipped", "max tow capacity is limited to the weakest link in vehicles ratings", or "towing weights must be within all ratings of the vehicle".
GCVWR - Is combined max weight rating for truck and trailer. Subtract 5700, from this number, and you will probably see your GVWR number.
GVWR - Is max weight on the truck.
Cargo Carrying Capacity (payload) - Is max weight for added accessories (bed liners, bed covering, nerf bars, etc), fuel, passengers, cargo, weight distribution hitch, and trailer tongue weight.
Hitch rating - Is max load on the veicle's hitch, with or without weight distribution.
Should be a sticker on your drivers side door post. It will show tire and loading information.
Find out your payload (it varies from one truck to another) number or cargo carrying capacity (CCC). Take your specific payload number, then figure everything that has been added (aftermarket accessories, bed liner, etc) to the truck, subtract its weight. Then figure everything and everybody, you plan to load into the truck, subtract that weight. Then subtract 100 lbs for a weight distributing hitch. Nobody here, can tell you what that number is going to be. We have no clue, as to what or who you will be carrying, what may have been added to your truck, or what your actual payload number is.
Whatever is left, is payload available for trailer tongue (hitch) weight. You need an available payload number in the area of 750 lbs to handle the trailers you are looking at.
When you know what your available payload is, divide that number by .13. The result is a ball park of what loaded (not UVW) trailer weight will put you at max weight on the truck. If that number is 400 lbs, your max loaded trailer would be about 3077 lbs (400/.13).
Next, check the hitch itself. Look for a sticker, or a stamp, showing its weight ratings. Its not unusual to see a hitch rating that is one tenth of your tow capacity number. In your case, that could be 570 lbs.
Too many people (including RV sales eople), get tunnel vision when looking a max tow capacity numbers. They forget about the fact that everything and everybody loaded into or on the truck, takes away payload and tow capacity, pound for pound, and normally, payload is gone first.
Now for the trailers:
GVWR - Gross weight on the trailer
UVW - Unloaded weight (before dealer installed options, batteries, and propane)
Unloaded hitch weight - Also before the dealer touches the trailer.
Hitch weight - Also termed tongue weight. Averages 12 - 13 percent of loaded trailer weight.
Average camping load (pots and pans, dishes, bedding, camping gear, groceries, and water) runs about 700 to 1000 lbs.
NOTE: Towing at or above max weight (doesn't matter if it is payload or tow capacity weight), can be very unpleasant. Possibly unsafe.
