TonySe's avatar
TonySe
Soft floor discussion (pics and steps to fix included)
We have a 2008 Aerolight that went soft at the front door...I have all the vinyl taken up and now I'm looking at the repair for the unit....the issue I've run up against is I don't know how the step gains strength through the floor....please watch the short vid (1min 30secs) for some details...
https://www.youtube.com/watch?v=x1q1M_qqBqc
Questions:
- Is the plywood normally glued to the foam core?
- Assuming it is, what glue is used to to secure the plywood to the foam core?
- The step is attached to a 2x4 between the plywood (instead of foam) for about a 6' span, but how does this wood get it's strength? There doesn't seem to be a stringer for the 2x4 to lay across to get strength.
Thanks for any help you can lend,
Tony
