MFL wrote:
My 250 is 350 suspended. The door sticker shows 75 front 80 rear, which I use for towing. When not towing, I run 70, front and rear. Just this amount of change, makes a huge difference.
Jerry
Now drop your pressure to 50-55 front and 40-45 rear and see how much more difference it makes. Try it you’ll like it!
Idk how anyone can ride around with 70-80psi in an empty 3/4-1ton truck and like it.
C rap, I aired the back tires on the ole Dodge up to 50 and put 10psi in the bags to pull a trailer this weekend.
Just that added little bit in the rear make it ride like I blocked the frame solid to the axle when I took the load off!
