WarrenS65's avatar
WarrenS65
Explorer II
Sep 16, 2022
Solar Install
I'm installing solar panels on my Host Everest. Does anyone know if the roof will support using self drilling screws, or do I need to hit a crossmember?
  • That tape is only as strong as what it's attached to. A screw into a roof member with a quality adhesive caulk works every time.
  • Ed_Gee wrote:
    Avoid holes all-together by using Scotch 3M VHB double sided heavy duty tape - # 4950.
    Using that on a rubber roof is a recipe for disaster!
  • I should have exempted rubber roof from my previous post. My concern is you having enough cross members in your roof to provide adequate mounting for solar panels.
  • Thanks KansasKen. I'll do that.
    Ed_Gee and Fishbreath: I have a rubber roof, so VHB tape is a no go for me.
  • The tape is great BUT it needs to stick to something substantial. For instance, not a rubber roof.
  • I second the VHB tape. That stuff is amazing. I have used it on three solar installs and have not had any failures.
  • Hitting a cross member on a roof without strong plywood is always the right way IMO.
  • Avoid holes all-together by using Scotch 3M VHB double sided heavy duty tape - # 4950.
  • used a quality stud finder to located aluminum frame members. Roof between frame members is foam sandwiched between two luan layers
