devildog1971 wrote:
I have a new northern Lite and the solar panel is not working is there a fuse? and if iso does anyone know where to look for it it is nor in the inverter converter box with the other fuses and circuit breakers. Thanks
Our '19 NL has the solar controller output, jacks, converter output, and the fridge (supply current for the DC boiler heater only--not the fridge DC control circuits) wired directly to the battery via 4 different leads (ours are labeled). There are resettable fuses for most (if not all) of these 4 circuits/leads located directly above the batteries. Just trace the leads back to confirm. None of these circuits/leads pass through the DC/AC fuse/power panel inside the camper. Hope this helps.
