work2much wrote:
full_mosey wrote:
What happens if you blanket an entire panel in a series or parallel array?
HTH;
John
In parallel you will only kill the production of that panel. For 3 panels, one covered you will still have 2/3 production. In parallel each panel contributes separately. Think of three hoses filling a bucket vs series where the three hoses are connected together with a single discharge into the bucket at a higher psi. The flow is limited by the smallest diameter hose in series where in parallel each hose can fill at their own rate.
OK, using the hose analogy, if you have three hoses in series and you step on ANY location ALL current stops.
HTH;
John
