StirCrazy
Jul 15, 2023Moderator
Nevrdun wrote:
05 Lance 1030 w solar panel. Panel is about 2.5’ square. I’m simply interested in knowing how to tell if it is recharging as it should. Thank you.
Use a multimeter and measure the voltage at the battery when the sun is out, and you're not hooked to shore power. if it's over 13V your panel is working. a 2.5' square isn't going to be a high wattage panel but it should be good enough to keep lights going.
44,070 PostsLatest Activity: Sep 18, 2026
