rodwha wrote:
These generators don't run on propane as well?
So the Backwoods wind turbine isn't a worthwhile accessory?
I figure parking under plenty of shade is a good thing reducing the need for A/C a bit, especially down south. I'm curious about tripods for solar panels. Of course I have no idea what the weight of 400-2000 watt panels would be.
Yup, some generators are setup to run on propane but gasoline is a richer fuel, re: weight of fuel. Also, gasoline seems easier to acquire than propane in some areas.
Wind turbines just don't make enough power to be viable for the typical RV'er. They can also be noisy and difficult to setup. I have one so kind of know what they can do. If you have a permanent site, a wind turbine can charge a battery. Typically, you need to locate it at least 15' above ground and away from any objects that block wind like houses, trees, etc. My propset is 7' in diameter but 10' diameter is a better size for harvesting.
Portable solar panels can be set up with just a set of attached legs, a board in back, or leaned against something stable. A tripod isn't necessary. Transporting multiple panels can be a PITA. The larger ones weigh around 40lbs. and the smaller, 100W panels about half that, 20 lbs. I have a single 235W panel and 300AH of battery capacity. That runs a small 120V fridge, my entertainment devices, and all the 12V stuff like lights, water pump, and fans. My furnace and water heater don't use electricity and all my alarms are self powered.
