When figuring your wattage needs I suggest a watt meter. They’re cheap and easy to use. It gives a quick and easy way to know what several, not all, appliances require. Figure out what energy you’re currently drawing then get a larger system than you think you’ll require. I used Renogy. Their install instructions were almost nonexistent but their tech dept is really good. Especially Tylor!
