pianotuna
Oct 09, 2021Nomad III
moonlitsouls wrote:pianotuna wrote:
Hi,
The inverter is a bit small. I'd got to 1500 or 2000 watt. Running a device "flat out" is not a good thing. At least one member burned out an inverter by doing so.
Fuses should be "at the capacity of the wire".
thanks for the feedback , i never use more than 1000w , its perfect for me.
what are your thoughts on the comment made by the guys on diy solar? i think there is an issue with the design and how the dc loads are being wired?
1000 running flat out is less efficient than a 2000 running at 50% load. Or are you saying your max load is only 500 watts?
