CA_Traveler
Oct 09, 2021Explorer III
I think he’s saying you don’t show the remaining house loads and the expected amps. So it’s inconsistent to show 4 ga and 2 ga on either side of the Blue Seas/switch. If the house loads and charger are connected to the Blue Seas switch then the different wire size would be more consistent than if connected to the busbars.
You can certainly have separate charger and inverter vs a combined unit. Just make sure your charger is adequate for the battery. I would question that as Li batteries are different.
Not sure why you show the gen, as I’d likely just show charger and it’s DC output to the house loads and how it connects to your diagram. Ie Your panel may have AC and DC in one physical panel but they are electrically separate (except for common grounding).
