moonlitsouls
Oct 09, 2021Explorer
CA Traveler wrote:pianotuna wrote:
The dc breaker from the solar panels is too small. If my batteries are hungry I get 17 amps from 256 watts of panels.X2 You have the potential of 60A+ maximum on the controller output.
The wire from the solar panels is on the small size unless all four panels are in series (which I do not recommend).He said series connection. IF his panels have bypass diodes then serial has shade and wiring advantages and hence I'd recommend it.
hey the 16amp breaker from the panels to the scc is because im wiring them in series , max amps will be 10
