StirCrazy
Oct 15, 2021Moderator
ok couple points. they are right, your not showing your DC house loads or taking them into account. run 2 ga to your bus bars from the batteries. all your lights, furnace and so on will draw pure 12V even if you have your inverter on so the largest draw you will experiance is between the batteries and your bus bars. also yes your dc house panel will have to go to the bus bars, ac section will not.. it will come of your auto transfer switch which allows you to switch between shore power/inverter power/dc power. you have a generator also, so you might need two auto transfer switches set up to turn off your charger when using the inverter and alow it to be on when using your genny or shore power.
I agree with some of the statments about the panels being a weird set up, do you already have them or are you purchasing.. if you havent purchased yet I would look into two larger 24V split cell panels. more efficient and only two to mount, I would look at around the 400 watt each, but I know that room constraints may restrict that.
Steve
Steve
