moonlitsouls's avatar
moonlitsouls
Solar Wiring Diagram for Review
Hi guys , hope all is well. Im in the process of upgrading my solar system , with the help of the DIY solar forum online ive been able to create this preliminary diagram but im still a little confused about how the existing ac/dc panel will be wired if im not upgrading the stock /converter charger. A lot of the videos i see online involve switching out the existing charger for a hybrid unit that does inverting and charging , i dont need that. My only goals are :
increase solar capacity
add the dc-dc charger
fuse the system properly
and clean up the install as it was thrown together by the rv dealer who sold the unit to the first owners , thanks a lot for the help
i received this feedback below from someone on the DIY solar forum and i have no idea what he means , pls help me out
"You show no pure dc loads.
That means the only load is the inverter so its kinda pointless to have the connections between the battery and the busbars at 2 awg and then the connection between the busbar and the inverter at 4 awg."
i think my system is designed incorrectly
for reference , this is a thread to the existing discussion on diy solar , any additional feedback would be greatly appreciated
https://diysolarforum.com/threads/pls-help-me-with-system-design.29437/page-4
  • pianotuna wrote:
    moonlitsouls wrote:
    pianotuna wrote:
    Hi,
    The inverter is a bit small. I'd got to 1500 or 2000 watt. Running a device "flat out" is not a good thing. At least one member burned out an inverter by doing so.
    Fuses should be "at the capacity of the wire".
    thanks for the feedback , i never use more than 1000w , its perfect for me.
    what are your thoughts on the comment made by the guys on diy solar? i think there is an issue with the design and how the dc loads are being wired?
    1000 running flat out is less efficient than a 2000 running at 50% load. Or are you saying your max load is only 500 watts?
    the purpose of this thread is to discuss sytem design and understand how my ac/dc panels will be wired into the system , im not concerned about my inverter size its working great.
  • moonlitsouls wrote:
    pianotuna wrote:
    Hi,
  • pianotuna wrote:
    Hi,
  • Hi,
    The dc breaker from the solar panels is too small. If my batteries are hungry I get 17 amps from 256 watts of panels.
    The wire from the solar panels is on the small size unless all four panels are in series (which I do not recommend).
