oughtsix
Jun 06, 2015Explorer
MANY solenoid valves will only operate when there is a minimum water pressure. Irrigation valves are like this, unless there is a minimum of 15psi or so they won't open because they use the water pressure to facilitate the opening of the valve. I do not know the specifics of the valve you posted but this is something you might want to consider when choosing a solenoid valve.
44,068 PostsLatest Activity: Jun 09, 2026
