Javi1 wrote:
Unless you have a smaller trailer that doesn't need W/D hitch then the 5'er is easier to setup and hook-up test pull or no test pull. ....snip............
My trailer is over 28 foot long and weights over 7500 pounds (which is not a "smaller trailer"). I don't need W/D since I use a 2500HD tow vehicle and I can be out the gate while the fiver is still removing his chocks which are necessary to do his test pull. I would not skip the test pull with my fiver, since a visual is not good enough for the hitch. I tow a lot, so I like to keep things quick, easy, and safe. (Not in that order)
