TucsonJim
Feb 25, 2016Explorer II
The microwave and coffee maker are on the 120V side of things, and the other items you list which aren't working are on the 12V side. The first thing I'd do is make sure your battery terminals are tight. If they are loose and not making good contact, it would cause your problems. Second, if the terminals are tight, I'd disconnect from shore power and use a volt meter to measure the battery voltage and make sure you have 12+VDC. It could bad battery. Also, while you're at it, plug back into shore power and see if the voltage at the battery terminals jumps back up to about 13.5VDC. This will let you know your converter is working correctly.
44,025 PostsLatest Activity: Feb 22, 2025
