westend
Feb 25, 2016Explorer
Rjwarfield wrote:This statement is confusing. You measured the battery voltage and it was normal but lights don't work. You plugged trailer into shore power and then everything worked, including the lights?
After I put a new battery in that tested at 12.63 volts I went back into the camper and tried the lights, still nothing worked as stated in the original post. I plugged the camper back in to ac power with the battery hooked up and still got 12.63-12.64 volts. Everything worked in camper after I plugged it in. ????
If so, check the circuit breaker close to the battery. It may be hidden underneath the frame or inside a box. When the converter is operational, you should measure at least 13.5 VDC across the battery terminals.
44,025 PostsLatest Activity: Feb 18, 2025
