Glowrdr's avatar
Glowrdr
Sorry... another wheel chock question
Been researching wheel chocks, and I bet I've read 50 different threads from all sorts of forums. Still have a couple of questions (coming from someone whose trailer has not left their driveway yet.
My trailer came with 2 of the camco plastic wedges, and to be honest - its downright scary to be in the trailer when unhooked from the TV (I have to use 4 2x8's under the tongue as my TV is quite tall).
After some extensive research, I really am interested in the Fastway ONEstep type chocks vs the "X" style chocks. Let me break it down, and hopefully you all can chime in and help me decide.
Fastway: Super simple to use, fast to deploy, I like that I won't have to crouch down to install/remove. But - I believe they have issues on non-level ground, and how well do they work if I'm on the legos?
X Chocks: Very well reviewed, they seem to make the most sense from an engineering standpoint, and I like that they aren't on the ground at all (not wet, muddy, sinking, etc). But, I'm hearing you still need regular chocks with them (at least to hook/unhook), and there are a few stories of them bending or not locking properly. I somewhat take that with a grain of salt though, as I'm sure if I look hard enough, I could find a story about an aluminum chock starting on fire and burning down a school full of orphaned mermaids under the sea.
Then there is the good ol' fashioned rubber triangle chocks. I'm talking the style used at truck stops. 10 inches wide, 8 inches high, weighing in at 8 pounds apiece with an eye bolt on the side. Just solid, no-slip, no crush rubber. After hearing the one-in-a-million horror stories of other chocks not living up to their name (or price) - I'm wondering if I just drop $30 on 4 of these (Northern is having an awesome sale at the moment)
With all of those thoughts typed out, what do the seasoned RV'ers recommend? Do I keep my little plastic chocks for (un)hooking from the TV, while deploying dual X chocks? Should I stick with the most basic of the 3 and grab the rubber? Or do I do something like get 1 X chock, and 1 Fastway (deploying the X on the leveled side)? Really want to get this taken care of before the first trip next weekend.
As always, thanks in advance!
  • X chocks are great for getting rid of motion inside the trailer but are not intended to keep the trailer from rolling away. A wedge chock does that best.
    My BIL lives in a lake community where there is a boat in every driveway. Some are very steep. Some people have put in anchors into the cement and use a safety chain to keep it from rolling down the steep incline should there wedge block get displaced.
    At the campground I use both the Xchocks and wedge chocks.
  • Never used anything but the x chocks when I had a trailer. They worked well to keep the trailer from rocking back and forth better than a wedge chock.
    Not sure what the conversation about hooking unhooking and not using x chocks was about. I just leveled it side to side, x chocked it, and unhooked, then leveled front to back.
  • Harbor freight sells some heavy duty rubber chocks that work very well.
