BradW's avatar
BradW
Explorer II
Sep 12, 2017
Speaking of tires and truck campers..........
We had our first truck flat while hauling our camper back in July while driving thru Memphis on our way to Colorado. The tire didn't really go flat, it had a belt separate and it started bouncing/shaking so bad that it was undrivable above about 40.
We made it to the next exit and ended up at a corner convenience store with an empty lot next door. My main concern was whether I had enough room to get the long steel rod into the hole in the rear bumper to crank the spare down. I remember checking that on our first truck, but that was 3 trucks ago. Lucky for us, it did go in......barely. I was glad I didn't have to lift the camper to get the rod in.
We put the spare on and drove on to Amarillo, Tx where we found a new tire the next day.
So, if you haven't actually checked to see if you can crank down your spare with the tc in the bed, you might want to check. If our camper had hung down another 1/2" or the overhang had been 6" longer, we would have had to lift the camper. I definitely would not want to do that on the side of the interstate.
  • Good Idea, I saw some place where a truck owner turned there mechanism so they could access it from the right wheel well
