TxTwoSome's avatar
TxTwoSome
Spread axle setup?
I see a few of the newer trailers being offered with what the dealer calls a spread axle setup with the wheels further apart and that is supposed to improve your towing experience.
Is this just dealer hype or a better axle setup?
  • hohenwald48 wrote:
    Probably work just fine as long as you only tow in a straight line.
    Aht the others have said, and it also allows for a lighter TW for many of todays lighter TVs.
  • Probably work just fine as long as you only tow in a straight line.
  • It's touted as a better towing setup.
    IMHO it's a way to spread the load out over a lightweight frame. And tire scuff on tight turns is horrendous along with camber changes.
