TecheMan
May 24, 2014Explorer
Spring load handlers ?
I just bought a 2012 2500 HD and it has some springs attached to the rear leaf springs. I put 1400 lbs in the bed and it only went down a few inches if that. I think these springs or hurting the unloaded ride by applying pressure to the leaf springs. Also rear of the truck sit up much higher than the front. Does anyone know what these springs are and how to get them off. I took pictures but I'm a dummy and don't know how to post them are maybe you can't do that here. They seam to hook on the back without bolts but are bolted in the front from under and over the leaf spring with a bracket. They have adjustable nuts on them but when loos they still seam to be held in place by torque from the leaf springs? Anyway the highway dividers in Louisiana are bad and I don't need any extra payload than this truck already has. Just trying to smooth out the ride a bit, I know it's a Truck and I bought a truck but I really think this is taking away from the ride.
Any help would be greatly appreciated.
Thanks Techeman
Thanks Techeman
