trackmagic
Dec 19, 2021Explorer
JimK-NY wrote:
You are happy with your rig and have used it several times. What concerns do you have? What advice are you asking for?
It seems that weight is the issue. If so, I can add that my TC is supposed to be 2300 lbs empty and setup for travel it weighs in well over 4000 lbs. I take extended trips and carry backup foods, a generator, 2 solar panels, 2 heavy AGM batteries and 3 seasons of clothing. Your use seems very different and you are likely not too much over the specs for your truck. I would check on ratings for your tires. Those are probably limiting you to roughly 3000 lbs per tire. You might be able to upgrade to improve the safety margin.
Each tire load for my BF Goodrich AT's is 3640lb.
You know, I guess I'm not really asking for specific advice.. The truck camper stuff is all new to me since I'm used to towing. So I guess I was just posting to either look for some gentle reassurance vs DON"T EVEN DRIVE THAT TRUCK ANOTHER MILE. And if the latter... I guess I would tuck my tail and think really hard about selling my new truck for a 1 ton.
44,071 PostsLatest Activity: Aug 08, 2026
