notsobigjoe
Dec 19, 2021Nomad III
If your 740 lbs over that would not bother me and many other truck campers on this forum and the rest of the truck camper forum universe. Then again the weight police would consider you massively over and in need of shaving off some additional weight. Where ever you fall in the middle of these two very different worlds is something your going to have to work out yourself. I'm not being snarky at all please don't think I'm being sarcastic. I'm usually over about 1500 pounds as well as a boat in tow and I could care less. If your comfortable with your rig then I say go with it, if your not then upgrade to the one ton. If I could give you some advice skip the 1 ton non dually and just get the dually. You'll be within every weight limit possible and you'll have the best ride out there. I hope this helps. Joe
