Reddog1
Feb 17, 2015Explorer II
Wagonqueen Truckster wrote:
Thanks so much Wayne. The pics help a lot. Question...
You are welcome.
How did you know where to center each side (plate length towards front or back) before bolting it in permanently?
The lift uses three jacks, two on one side, and one on the other. You identify the COG of your TC, and mount the single side jack at that point. On the other side of the lift measure the center between the two jacks, and that point should be the COG on that side. If you are off a couple of inches, I really do not think it makes any difference.
AND... do you have a manual?
I think I have a couple of instruction sheets. I gotta say, they leave a lot to be desired. The only real issue is setting the frame saddle to "hoop" pre-load. If you buy the lift, I will explain it to you. It is not a major setting as it pertains to difficulty, but is important.
I encourage you to call Stable Lift, and ask them questions. Ask for Mont. They are very helpful and easy to talk to, even though you are buying a used lift. Keep in mind, your experience can impact their future sales.
