Crumm wrote:
languiduck wrote:
That may be the most confusing thing I have ever read in my life. You either have 2, 3, 4, or 6 plates according to what you've written.
He has three on the right front, three on the right rear, three on the left front and two on the left rear. His question is would it be ok to run four on the left front and two on the left rear. Simple answer would be try it and see. Might be fine with 3/2 also as the crown in the road leans truck to right.
The uneven gap may be from a uneven spring pad, wore spring, manufacturing glitch, axle wrap or many other things. They are just leaf springs not rocket engines so it doesn't really matter. If you are going to put stable load steel wedges between them they will be wore out before long anyway.
Thanks for understanding, couldn't figure out any other way to be more clear on this. I did put the 4th on drive side front and it fit fine. Needed a longer bolt that holds the sandwich of plates together but that was easy. I now have the same spacing on both 2 front stable loads and both 2 rear stable loads. Will load camper Wed and report how it went.
