elkrott's avatar
elkrott
Stained LP Gas Tank Cover
Any suggestions to remove stains from LP gas tank hard cover?
Tried rubbing compound and simply awesome cleaner.
  • Posting a picture of the stain could be helpful along with the source of the stain, if known. Different stains can be treated differently. And was that L.A.'s Totally Awesome or Simple Green that you used. For the toughest of stains, L.A.'s Totally Awesome usually does a great job but has it's limitations.
    I would be tempted to use lighter fluid (not charcoal starter fluid) as it is a mild petroleum distillate and safe on every plastic I've ever used it on. Failing that, try a light rubbing of acetone on a discrete area to see if it will dissolve the plastic before going after the affected area.
    Indeed, painting with Krylon Fusion or other paint designed for plastic would be acceptable after a good surface prep/wash.
  • I sprayed my cover with this product, came out great. One can did a cover for two 20lb tanks....
    https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CCoQFjAA&url=http%3A%2F%2Fwww.plastidip.com%2F&ei=reCaU6WzHti2yATwpIHQAw&usg=AFQjCNET9QMorHCqybhafrWZgf2kYcpItQ&bvm=bv.68911936,d.cWc
  • If all fails, get a new one. They are not that expensive.
    Currently under $20 at CW.
    Good luck.
  • How about mr. Clean magic eraser? If you've used rubbing compound, you've introduced tiny scratches. So, you can paint it. I assume it is plastic, so try spray paint for plastic lawn furniture.
