scout266's avatar
scout266
Starcraft fresh water pump/dry camping
Ok, so I have a 2014 Starcraft AR-ONE. This weekend was my first time using it at a location with no hook-ups. Before the trip, I read the manual and it stated that if I was dry camping I could attach a hose to the city water fill point and put the other end of the hose in a source of fresh water (I used my large prepper-type water containers which did not have a spout, otherwise I would just have poured the water in the fresh water fill port). The manual went on to say that you would then just turn on the water pump switch inside the trailer (DC operated) and the water would be pulled from the water jug into the RV. The only note it said was to allow additional time for this process.
Well, I went on the trip and no attempts of this process worked. I tried "priming" the water hose with water (not mentioned in the manual) and that didn't help. There was zero suction on the hose. I called starcraft and at first the lady said you can't do this--but I read the manual verbatim. She then handed me off to a tech, who said "yeah, it's a pain in the butt." He mentioned priming it with water, etc. but that was no help.
So, I'm a little pissed because I read the manual before I purchased the TT and knew that this was an advertised capability. I now just wonder if it is not at all set up to do this and that the manual is just misprinted. To add, the water pump does work just fine at pumping fresh water in/around the trailer--It seems to work as advertised for the normal function.
I ended up going to Wal Mart and buying a couple of 6 gallon jugs with handles and spouts to do the job.
Any help/info/comments would be appreciated. I'm a bit of a newbie to Travel Trailers.
