bigfootford
Apr 18, 2017Nomad III
First, use absolute caution using jumper cables or even installing new batteries!
Even if someone helps you jump it... Watch like a HAWK! Know that + goes to + and - goes to -!!!!
Why?
There have been many disasters posted here on RV.net of folks hooking their batteries backwards and blowing all of the voltage sensitive appliances etc electronics... BIG $$$!
ABSOLUTE attention to polarity is necessary.
That said... There are many issues you will need to learn about.....A crawl before you walk thing.
Your camper can not sit over 1-2 months without shore power on it or have solar to maintain your batteries.. Other wise you will be replacing batteries yearly.
If you could disclose an approximate where you live there should be some RV.net TC'er nearby that could help and teach you....
Do not go out and purchase batteries without first determining what type of Converter/charger you have.
The box that sits under the step is where the converter is on the BF.
Open the little door and check the make and model...
If it a Magnetek you will need to upgrade that. I am not sure what year they upgraded.
I can not even imagine AGM batteries being maintained by a magnetek so maybe the previous owner upgraded or the factory did.
Hope there is someone nearby that can help you get started!
Congratulations on your combo truck and camper... We love our BF... had it 17 years now... nearly 200,000 miles on it... hahahaaaa 2 trucks.
Jim
Why?
Jim
