mkirsch
Apr 19, 2017Nomad II
Normally you do not want to run a vehicle with a dead or missing battery. This is because the regulator on the charging system will run wild trying to charge the dead/nonexistent battery, and burn out the regulator.
That is a general rule of thumb. I don't know how an Onan generator works in this respect, if it has an alternator built in or if it depends on the camper's converter to charge the battery. You might want to make sure before you fire up the generator, disconnect the jumper cables, and damage something.
