valhalla360 wrote:
Terryallan wrote:
so you are saying. They should only make ONE rear gear ratio? Wonder why they still make lower gears, and rate them to tow so much more? It's a puzzle.
Not sure how you came up with that?
The 10speed means you have a gear ratio available that matches what the rig needs to what the engine produces.
With the old 3 speed transmissions, you often wound up having to drop down to a gear that was too deep, so the engine would be lightly loaded but screaming at high RPM when towing. A deeper rear-end could allow you to run in the higher gear and keep the engine better loaded at lower RPM. (This assumes you are within ratings with either rear-end...no one is suggesting towing beyond the ratings). Of course when not towing, the truck winds up running higher RPM and less efficient. And even with the deeper rear-end, it still didn't always match up well to power needs.
With the 10speed, those issues largely go away. For a given situation, the truck may pick a different gear if the rear-end is changed out but the overall gear ratio will be nearly identical.
Only reason you might need a deeper rear-end is to boost the ultimate towing capability but the discussion presumes he isn't over the tow rating and it is about drive-ability.
I just go by the rating for the different gears. and YES they make a huge difference, Especially up, and down mountains, and starting from a stop. that is one of the reason for the lower gears. Another is keeping the engine in it's power band. Still a puzzle.
If you had ever seen the difference in gear ratios as they run. you would better understand the difference, between a 3.73, and a 3.05. I see it every day. It is what I do.
