NCMODELA wrote:
Dang. You learn something new everyday. It take it that it doesn't help the young is on a piece of wood.
Is this dangerous or when I pull it out it will be okay?
Take a set of jumper cables and temporarily connect the RV frame to a Temporary Ground Rod (of some kind) and then remove the wood from under the tongue jack. If necessary replace the wooden platform with a metal platform if the soil is such that the jack is going to be driven into the soil too far. Once complete you can remove the Temporary Ground Rod connection.
