jimh425 wrote:
It sounds like you would be better off with a less aggressive tire that is the same front and rear which will allow you to rotate tires.
I do like the idea of being able to rotate my tires as I do with all of my other sets of tires. I always mount them ontheir own rims so that is not an issue.
I guess I missed one other option ... that is to go with steer tires on the front and drive tires on the back. Again, that takes away the rotating option.
Anyone out there use a "hybrid" steer/drive tire like this one?
GT Radial Steer & Drive Tire
