johndeerefarmer's avatar
johndeerefarmer
Explorer III
Jan 04, 2014
Steering/Ride Quality of Big Three HD trucks
I have had two Ford diesels- an 05 with the famous death wobble. I then went half ton for awhile but then got a '13 Powerstroke. The steering wheel would still move with every imperfection in the road. I tried both 2wd with the Twin I beam and the solid axle four wheel drive -both stink.
I need a truck with NO feedback from the road to the steering wheel. I have tendonitis in both elbows and all of the movement of the steering wheel makes my arms hurt so bad that I can't drive for very long. I dumped the Powerstroke for a F150 but need a HD truck again.
If you have a Duramax how is the steering? If you let go of the steering wheel and drive down the road or thru a pasture does the wheel move with every imperfection in the road?
If you have had a Dodge, how was the steering on it? The report on pickuptrucks.com said that the Dodge had the best feeling steering but that's hard to believe since it's got a solid front axle.
Ride quality, as far as the rear end bouncing on bumps isn't as big of a concern but any input there would be helpful too.
