kvangil wrote:
Lynnmor wrote:
You need to carefully level the trailer frame side to side and front to back using a good 4 ft level. Don't use the stab jacks when doing this. Stick levels on opposite corners, one front, one rear and on each side.
Might be overkill for a hybrid? ;) We use a stick-on that we put on the top of the A-frame for leveling side-to-side, and another one on the side of the A-frame that is used for measuring front to back (also used for measuring hitching angle). When both bubbles are in the middle, we're good to go. This placement works for us, so we don't have to run back and forth or have someone spotting from the side. But...Everyone has their methods, so YMMV. :)
Since the OP wanted instructions, the above process was for installing the levels, not for each and every time you camp. If you ever checked the tongue (A-frame) of a trailer you might find it to be a very poor choice for locating a level.
