d3500ram wrote:
Not sure exactly how your spring set-up is, but I added a couple of user mods which along with added Helwing and Ranchos made for an almost ideal ride and height.
I made perch extenders for the top factory helper springs from 2" TS to engage sooner. I installed timber felling wedges to allow the stock bottom overloads to engage sooner. All this made the springs do the intended work before needing to put a lot of weight in to engage the them.
I do not have the camper anymore, but have used it recently to haul several loads of gravel for home construction projects... one load was just over 2 tons... about the same weight as my maxed out fully loaded camper setup.
Cheap modifications.
Very clever!
My ride height is fine. So I think my springs are fine. Maybe I’ve added too much spring capacity?
On the 1200 mile drive home from buying the camper we had sway and roll, but not the skittish behavior we’re getting now. The sway was even less on the ride home when we filled the water tank, though I could still tell we would benefit from a sway bar. We even drove for about 30 miles with 40mph side winds and I was only moderately nervous.
I can deal with the feeling of some roll and sway. The unnerving thing is the quick dip to one side before the helper springs appear to come into play.
Would airbags fill the gap, so to speak?
