Haloo wrote:
Yep, I understand that some sway and roll come with the territory. It did for the 1200 mile drive home with the camper. After I added the helper springs there is the initial tippy thing that wasn’t there before.
You can reload the overloads by extending your bump stops. Air bags will make the feeling worse if you put any air in them. I have air bags which are roughly equivalent to your helper springs.
I use Energy Suspension Bump Stops like these.
https://www.amazon.com/dp/B000CNB5OU/ref=cm_sw_r_oth_tai_d7hNFbNSCEH3X
