Haloo wrote:
2019
Yep, I understand that some sway and roll come with the territory. It did for the 1200 mile drive home with the camper. After I added the helper springs there is the initial tippy thing that wasn’t there before.
It sounds like you now have to much spring. (to stiff?) If it rode better before I'd remove the helper springs.
I have a 9.6 on a 17' F250 and only added airbags to level out the headlights. (the 9.6 and 8.11 weigh about the same)
As you and others have mentioned, some side to side sway goes with a top heavy setup. Some of the sway will be from the suspension and some will be from sidewall flex of your tires.
Personally, the sway I was getting from the stock Ford OEM tires (rated at only 3450lbs) was to much to bear so I swapped the tires and rims for 19.5 Vision heavy hauler 81's and 265/70 Toyo M608Z's.
I have no sway bar.
Essentially I fixed my sway/handling issues with tires+rims.
YMMV.
- Mark0.
