Haloo wrote:
srschang wrote:
What are you running for air pressure in the front & rear tires? Are the tires load Range E? F? G? A tire with a firm sidewall makes a big difference in side to side sway. As others have said, some of it is a learning experience, especially when entering and leaving parking lots. You generally want to do it as square as possible, if you are at an angle one of the front tires will go over any dip or bump first, starting the camper rocking, then when the rear tire go through it one at a time, it really gets to rock & rolling.
Scott
60lbs front, 80lbs rear. Load range E, 20” tires.
The primary issue is kind of a skittish feeling, not a roll so much as a sudden dipping to the outside of the curve — like it dips then catches.
We drove the camper home 1200 miles on the stock springs. There was some sway and roll, but no big deal. After the new springs were added it feels different as I describe above.
I think you answered your own question. NL are not very heavy and should be well within 1 ton stock suspension.
OE shocks should be fine...can’t believe they are worn already. “Adjustable” shocks are useless in snow country. They won’t be adjustable for long.
Of all the suspension mods I have done (many!) sway bar was the most useless. Made no difference IMO.
Go back to your OE suspension and put on a few miles. Then re-evealuate.
