fj12ryder wrote:
Okay, I'm a little confused. Where does the air come from that displaces the fuel as it's pumped out and used? Or does it create a vacuum? If the air isn't run through a drier, then it will have some water vapor in it, which can condense out and precipitate into the fuel.
The "air" inside the tank isn't being exchanged rapidly and you probably get more water in your tank if you fill up a capless fuel tank in the rain than what would happen sitting all winter.
Bottom line, the rvnet contingent generally remembers too many things from the past and try to apply them to the present, sometimes incorrectly. This is one of those things.
Diesel, yeah, who cares...fill it, leave it low, doesn't matter since the fuel if full will still be good come spring time. It's a whatever helps you sleep at night thing.
Gasoline, different story although also less of an issue with stale fuel with most newer (last 20-30 years) efi systems. The bigger issue is firing up the RV on a full tank of stanky old 87 E10 (even with stabil, to a point) and then pointing big bertha up the hill full throttle for the first pull of the year on suspect fuel.
