Vvvv1010's avatar
Vvvv1010
Stove top covers for additional counter space
Any thoughts or experiences on the following 3 covers. They are all in the $45 - $55 range and the color my wife and I are interested in is black.
Our stove is the Wedgewood Vison 3 burner.
1. Atwood Bi-fold cover
2. Decor-mate stove topper
3. Camco Universal Fit Stove top
I'm leaning toward the Atwood.
Our Jayco is very limited on counter space and we rarely, if ever, use the burners.
  • 2oldman wrote:
    How do you cook?
    I have the wedgewood vision 2 burner and wanted the same thing. since we usually microwave everything not cooked outside I made a wooden cover out of 1x3s and some 1/4 inch plywood. stained the boards to match and put 4 self stick vinyl tiles on the top that closely match the counter top. can set it on the bed if we need to use the stove.
    it sits a little higher than needed, the next size 1 x 2s were too short so I may take it to my table saw and lower the sides a little, unfortunately, I put in one nail per corner and of course they are located exactly where I would need to cut.
    bumpy
    How do you cook?
  • We have a top cover similar to the Atwood. Here's how we use it to increase counter space. The only time I need extra space, I generally have something on to cook. One thing though......if I'm using the back burners, I take anything off the shelf. The second pic shows how it's done. DH drilled small holes in the fan and the top, then cut a wire hanger to use to hold up the shelf. Note: the shelf is NOT slanted like that --- an optical illusion and I'm not going out to take another pic :) :)
    I would not get anything other than the Atwood. It folds into a backsplash and when deployed it provides a usable surface. However it does flex a bit under heavy weights so if you have intentions of putting heavy stuff on this then a butcher-block wooden top is probably strongest.
