Anode rod head is soft steel with a steel rod that the magnesium (or aluminum) sacrificial material is formed around
Flat surface on head.......aluminum material on rod
Bump on surface of head....magnesium material on rod
Suburban uses an anode rod because tank is a 'glass-lined steel' tank.
Sometimes it helps trying to 'tighten' a stuck bolt FIRST before trying to unscrew it.
Anode rod is necessary to protect that steel tank from rusting out.
Suburban tanks are not available for replacement....have to replace WHOLE water heater
Drill it then E-Z out it
After removal.....use a 3/4" NPT pipe nipple to chase drain hole threads (clean up/straighten them)
