joerg68
Jan 08, 2019Nomad III
Do not use PT wood in the camper. It can be highly corrosive due to the chemicals used. So the wood may hold up, but may cause issues with any metal parts around it, such as aluminum siding. See https://galvanizeit.org/hot-dip-galvanizing/how-long-does-hdg-last/contact-with-treated-wood for more info, or just google "pt wood corrosion".
It also used to contain arsenic, but this has been banned for about 15 years now, so any PT wood currently on the shelves should no longer contain any.
See https://en.wikipedia.org/wiki/Chromated_copper_arsenate for more info if you like. However... the chemicals now used for the purpose may or may not be safer, I do not know.
ETA: this document has some impressive images of steel vs. PT lumber:http://www.ggashi.com/wordpress/wp-content/uploads/PT-Lumber-Causes-Steel-Corrosion.pdf
