NorthwestBound wrote:
Without a 5th wheel hooked up, i backed my TV into some wet grass to load up my 5th wheel hitch. Tried to pull out and realized i was stuck.
Any suggestions would be appreciated.
Wow, I've been there many times. My old truck was an '04 Chevy 2500 HD 2WD. It was originally an open differential axle......talk about ZERO traction. After a couple of years I installed an Eaton Limited slip Diff along with Transforce AT tires. That combo worked okay but I still got stuck occasionally. Last summer I got stuck pulling the TT and that was the last straw. As you see in my sig, I upgraded to a Cummins 4X4.
Don't get me wrong, the 2WD can work fine 95% of the time. I just got tired of needed to always have a tow strap or other tools on hand just in case I got stuck.
