AnEv942
Aug 14, 2017Nomad
If it had access panels on the inside to the release rods you might have better luck forcing it open.
Possibly jacking truck at rear corner to twist.
Never tried, mine has small cut outs where pin passes the inside wall of gate- I can see pin and pawls, might get a screwdriver to pry the pawls off pin from bed side.
If you end up cutting I'd remove as much as possible- panels release rod etc. shells cheap
