On theProwl wrote:
Thanks for all the replies! I definitely have some thinking to do, but leaning toward the B&W. I like the thought of having a gooseneck ball available if ever needed.
Our TV is a '16 Ram 3500 SB. Basically the same truck you have. Our 5th wheel weighs approx. 12k loaded.
I'll leave it up to everybody else to hash out the brand-war.
The height requirement for your prospective hitch may drive your choice more than anything else. If you need a hitch much lower than 16" or so, you're going to find your choices more limited. Sure don't want to tow nose high. See a lot of that on the road.
Also, be careful with your choice of a slider hitch if you decide to get one. Measure carefully. We almost purchased a slider that slides back 12". Come to find out we only 11.5" of clearance between the rear of our king pin assembly and the tailgate. That would have been an expensive mistake.
Fortunately, we were able to borrow a hitch and make some critical measurements before we purchased a new hitch. So glad we did. We ended up needing a hitch about 13-14" high. Almost purchased a new $1300 brandname hitch the day before. We would have been way nose high with that particular hitch adjusted to it's lowest position.
Good luck!
