gkerlin's avatar
gkerlin
SuperTruss Extension Removal Question
Hey Folks.
Those of you experienced in the use of the Super Hitch SuperTruss Extension…
I just put mine together today. It seems impossible to get it out of the receiver unless I loosen up all the bolts on the U Brackets and then slide each tube out separately.
Trying to do them both at the same time… ugggg I can wiggle them a bit up and down while I try to pull them out - but the don't seem to budge.
I thought perhaps I'd sand the paint off of the tubes where they enter the receiver and perhaps see what I could do inside the receiver as well - but before I go nuts…
Is it normal to have to loosen up the whole assembly to remove it?
Anybody able to keep theirs all torqued up and side it in and out? A quick attach of the chains and tighten the turnbuckles and you are ready to go???
