Boband4's avatar
Boband4
Support while wheels are off
I need to take the wheels in to have new tires intalled. I am trying to figure a way to support the trailer with all 4 wheels off. I would like to make it in 1 trip, that is why I want to do all 4 at once. I don't want to use the stab jacks to support it without the wheels. Any suggeztions on how best to support the trailer while all 4 wheels are off?
  • I would use jack stands. There are no less than 6 or 8 of them in my garage of various sizes for the job.
  • 73guna wrote:
    Id use 4 jack stands on the frame.
    This is just my opinion, but please do not use cement blocks to support your trailer.
    X2. I once saw a cement block disintegrate while being used to prop up a car. It just fell apart for no apparent reason. Good thing nobody was under it at the time.
  • I did this. Put six axle stands under the frame around the suspension and dropped all four stabilizers down. Piece of cake.
  • I have used stand jacks and/or concrete blocks on my 25 ft. TT.
    Since I am on sand ground, I put 2x12s on the ground and 1x6s between the frame and the blocks next to the wheels.
    It is a lot easier to do one side at a time. It is even easier to drop the TT off at the tire shop and let them do it.
    Good luck
  • I did that a couple times and made two trips. PITN.
    Take the trailer down and just get it done. Four floor jacks and the new tires are on in a few minutes. Make sure they hand torque the lugs.
  • I put concrete blocks under the frame with 2x12's stacked on top, use floor jack close to spring shackles to raise each wheel then put 4x4 or 6x6 blocks under shackles so I can service wheel bearings at the same time...yes...it's a pain in the butt. Thank goodness it only needs done every other year.
